Lexmark MX611de Maintenance Kit Replacement
  1. Lexmark MX611de Maintenance Kit Replacement, Right Cover Removal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lexmark MX611de Maintenance Kit Replacement, Right Cover Removal: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the paper tray
    • Remove the screw securing the right cover to the front of the printer frame.
    • Open the memory access cover that is attached to the right cover
    • Remove the two screws securing the right cover to the RIP shield.
    • Slightly lift the printer, slide the right cover forward, and pull it out and away from the printer
    • Remove the screw securing the left cover to the front of the printer frame.
    • Release the Two tabs on the bottom of the cover.
    • Pull the cover forward, and remove it from the printer.
    • Open rear door.
    • Pull the exit door upward to release the hinges, and remove.
    • Remove the two screws securing the rear cover.
    • Remove the cover.
    • Remove the three screws from the Left Mounting Bracket
    • Two different ways to the next step, dependent on experience and/or confidence.
    • Move the the Mounting Bracket over while extending the Stapler Cable out of the way, The Stapler cable does not have to disconnected.
    • Remove the Stapler Cable and Mounting bracket from the printer frame while feeding the cable through the redrive unit and printer frame.
    • Using a pair of pliers, squeeze the nylon mounts to dislodge the stapler connector, and remove the cable.
    • Remove the three screws from the Right mounting bracket.
    • Remove the Two screws, and then disconnect the reverse solenoid.
    • Do not disconnect the reverse solenoid cable from the controller board.
    • Remove the Six screws securing the redrive assembly.
    • Disconnect the cable JEXIT1 from the controller board.
    • Disconnect the Two cables.
    • Remove the Two screws securing the fuser.
alarson118
crwdns2935283:002/24/15crwdne2935283:0
553 crwdns2915208:0crwdne2915208:0
Tech-zone crwdns2935289:0Tech-zonecrwdne2935289:0
Business
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 61
crwdns2942667:0crwdne2942667:0 5,792
