Lexibook Junior Tablet Charging Port Replacement
  1. Lexibook Junior Tablet Charging Port Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure your device is powered off before replacement to prevent electric shock.
    • With the device screen face down, use the metal spudger to remove the small rubber circles on all four corners of the device. The screws should now be revealed.
    • Using the metal spudger, pry open the small, long rubber rectangle on the back of the device to reveal more screws.
  2. Lexibook Junior Tablet Charging Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #00 screwdriver, remove the four 6.8mm screws from the four corners of the device.
    • Using the same screwdriver, remove the three screws that were behind the rubber rectangle. These screws do not come out of the device.
    • Use the plastic opening tool to gently pry open the back panel of the tablet.
  3. Lexibook Junior Tablet Charging Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the nylon spudger to gently pry under the battery to remove it.
    • Make sure you do not damage the battery or metal plate in this process and only use a nylon spudger. Be patient and work slowly for the best results.
  4. Lexibook Junior Tablet Charging Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a soldering iron to remove the battery from the motherboard safely.
    • For advice on how to solder, check out iFixit's Soldering Guide.
  5. Lexibook Junior Tablet Charging Port Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lexibook Junior Tablet Charging Port Replacement, Motherboard: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the plastic opening tool, gently push the two small, black and white switches out in the direction of the ribbon wires.
    • Slowly pull the ribbon wire out of the switch to free it.
  6. Lexibook Junior Tablet Charging Port Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push the larger black and white strip leading to a ribbon wire upward using the plastic opening tool.
    • Carefully pull the ribbon wire out of the switch
  7. Lexibook Junior Tablet Charging Port Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lexibook Junior Tablet Charging Port Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lexibook Junior Tablet Charging Port Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the five 4 mm screws around the perimeter of the motherboard using the ph00 size phillips head screwdriver.
  8. Lexibook Junior Tablet Charging Port Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lexibook Junior Tablet Charging Port Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the button board by unscrewing two more 4 mm screws and one 6.5 mm screw
  9. Lexibook Junior Tablet Charging Port Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Solder off connections from the wire connecting the motherboard to the speaker.
    • For how to solder, check out iFixit's Soldering Guide.
  10. Lexibook Junior Tablet Charging Port Replacement, Charging Port: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lexibook Junior Tablet Charging Port Replacement, Charging Port: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
Rachel Klesius
crwdns2935283:009/19/16crwdne2935283:0
645 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 17-3, Blackwell Fall 2016 crwdns2935289:0USF Tampa, Team 17-3, Blackwell Fall 2016crwdne2935289:0
USFT-BLACKWELL-F16S17G3
crwdns2936753:030crwdne2936753:0 39
crwdns2942667:0crwdne2942667:0 949
