Lexibook Junior Tablet Battery Replacement
  1. Lexibook Junior Tablet Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure your device is powered off before replacement to prevent electric shock.
    • With the device screen face down, use the metal spudger to remove the small rubber circles on all four corners of the device. The screws should now be revealed.
    • Using the metal spudger, pry open the small, long rubber rectangle on the back of the device to reveal more screws.
  2. Lexibook Junior Tablet Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #00 screwdriver, remove the four 6.8mm screws from the four corners of the device.
    • Using the same screwdriver, remove the three screws that were behind the rubber rectangle. These screws do not come out of the device.
    • Use the plastic opening tool to gently pry open the back panel of the tablet.
  3. Lexibook Junior Tablet Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the nylon spudger to gently pry under the battery to remove it.
    • Make sure you do not damage the battery or metal plate in this process and only use a nylon spudger. Be patient and work slowly for the best results.
  4. Lexibook Junior Tablet Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a soldering iron to remove the battery from the motherboard safely.
    • For advice on how to solder, check out iFixit's Soldering Guide.
Rachel Klesius
crwdns2935283:009/19/16crwdne2935283:0
645 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 17-3, Blackwell Fall 2016 crwdns2935289:0USF Tampa, Team 17-3, Blackwell Fall 2016crwdne2935289:0
USFT-BLACKWELL-F16S17G3
Bonjour avez vous lien pour l'achat de la batterie en question. Merci
Akrame Chakir - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,344
