Lew's Mach Crush Speed Spool Disassembly
crwdns2931587:0crwdne2931587:0
    • Refer to the featured document for specific part names and exploded view. Determine whether you have the right-handed or left-handed reel.
  1. Lew's Mach Crush Speed Spool Disassembly, Remove Left-Side Cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lew's Mach Crush Speed Spool Disassembly, Remove Left-Side Cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide switch to 'open' on left side of reel to remove left cover.
  2. Lew's Mach Crush Speed Spool Disassembly, Spool Assembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the palm-side cover, then spool assembly from center frame of reel.
  3. Lew's Mach Crush Speed Spool Disassembly, Lube-Port Screw: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove lube-port screw using small Phillips screwdriver.
  4. Lew's Mach Crush Speed Spool Disassembly, Lube-Port Cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove cover off of lube-port.
  5. Lew's Mach Crush Speed Spool Disassembly, Handle Screw: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove screw and handle nut from reel.
  6. Lew's Mach Crush Speed Spool Disassembly, Removal of Handle: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove handle and handle nut retainer.
  7. Lew's Mach Crush Speed Spool Disassembly, Drag-Dial: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew star-drag until it is loose, remove it and the handle washer from the shaft.
    • Note: You may have to hold the reels gears in place in order to unscrew the drag, as it will try to spin the gears.
  8. Lew's Mach Crush Speed Spool Disassembly, Exterior Right-Cover Screws: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove three spool cover screws from reel.
  9. Lew's Mach Crush Speed Spool Disassembly, Cap: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove cast control cap.
  10. Lew's Mach Crush Speed Spool Disassembly, Removal of Right-Cover: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry 2 drag spring washers, and 1 click holder washer off to finish removing side cover.
  11. Lew's Mach Crush Speed Spool Disassembly, Removal of Pinion: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the pinion yoke and 2 pinion yoke springs
  12. Lew's Mach Crush Speed Spool Disassembly, Removal of Main Gear: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove drive gear and accompanying drag and ratchet washers.
  13. Lew's Mach Crush Speed Spool Disassembly, Apply Oil: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply oil to main gear if desired.
  14. Lew's Mach Crush Speed Spool Disassembly, Make any necessary changes: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • At this point, you have disassembled the reel enough to where you can clean parts, remove dust and debris , or replace individual parts
crwdns2935103:0crwdne2935103:0
Rebecca Welch
crwdns2935283:003/31/22crwdne2935283:0
250 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 701
