If your Levoit LVAC-200 vacuum cleaner's suction power has diminished, a clogged hose might be the culprit. Over time, debris can accumulate, leading to blockages that hinder performance. This guide will walk you through the steps to safely disassemble the hose and identify or resolve clogs. By following these instructions, you can restore your vacuum's efficiency and extend its lifespan.
Before starting, ensure the device is powered off and unplugged for your safety.
Let's get started !
Press down on the vacuum head release button while pulling the vacuum body away.
If you notice any debris in the hosing, remove it.
