This guide will walk you through the simple process of replacing the battery in your Levoit LVAC-200 canister. Follow the directions provided below to get your canister back to action!
Press down on the white button located on the side of the vacuum.
Gently pull on dust bin to remove it from vacuum body.
Press the white button located on the end of the dust bin.
Dump the contents into the trash, or replace the dustbin.
