Les Paul Wireless Guitar Strummer Replacement
  1. Les Paul Wireless Guitar Strummer Replacement, Les Paul Wireless Guitar Body Teardown: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove batteries
  2. Les Paul Wireless Guitar Strummer Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Les Paul Wireless Guitar Strummer Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove void warranty sticker
    • The sticker is covering a torx screw
  3. Les Paul Wireless Guitar Strummer Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Les Paul Wireless Guitar Strummer Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Les Paul Wireless Guitar Strummer Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the 11 screws securing the back of the body using a T10 Torx screwdriver. Each screw is 1 cm long.
    • Push level, this will detach the back of the guitar from the front.
    • Carefully remove the back of the body
    • The battery pack cord is attached to both sides of the guitar, be careful not to tear it apart.
    • The neck connector may be stuck to the back so be sure to detach it before fully pulling
  4. Les Paul Wireless Guitar Strummer Replacement, Strummer: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Les Paul Wireless Guitar Strummer Replacement, Strummer: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 4 screws from the back of the strum chip using a Phillips PH1 screwdriver. each of these screws are 1.2 cm each.
    • Remove the 4 inner screws, each are 0.8 cm.
    • Make sure that when putting back together, the 4 inner screws line up with the small plastic piece underneath.
  5. Les Paul Wireless Guitar Strummer Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Les Paul Wireless Guitar Strummer Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Les Paul Wireless Guitar Strummer Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two plastic holders on the underside of the chip.
    • Pull out the the plastic piece on each side of the strummer.
    • Lift the strummer out of it's location
    Note: If you find any loose rectangular rubber feet inside the body upon opening, do not discard! There are a total of Four rubber feet that push onto the Strummer rocker to aid in buffering the Strummer hits during play. With Strummer piece out and facing finger side up, you will see four rectangular tabs with slots, these slots are where they attach. They bump against the plastic fins on the body face when reassembled.
    John Pferdehirt - crwdns2934203:0crwdne2934203:0
    Note on Strummer rubber bumpers. Add a small bit of adhesive to them to keep them from falling off again. A dab of Silicone sealant works great
  6. Les Paul Wireless Guitar Strummer Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Les Paul Wireless Guitar Strummer Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Les Paul Wireless Guitar Strummer Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Take the top black cover off the strummer.
    • Slide the black rod out of the side.
    • Clean if needed.
Chris
crwdns2935283:010/18/13crwdne2935283:0
905 crwdns2915208:0crwdne2915208:0
Hi recently bought this controller again and the up strum has stopped functioning. Hoping this will fix it. Thanks
liamiley91 - crwdns2934203:0crwdne2934203:0
Did this fix your issue? Thinking about trying it.
D. Preston Peek -
Same here, i want to it try but want to know if i will be able to do it altough i’m not really good with these kind of work
Sébastien Fortuny - crwdns2934203:0crwdne2934203:0
This guitar don't have star power with up guitar? Where is sensor?
Leandro Loureiro - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 77
crwdns2942667:0crwdne2942667:0 21,045
