Les Paul Wireless Guitar Strummer Replacement
  1. Les Paul Wireless Guitar Strummer Replacement, Les Paul Wireless Guitar Body Teardown: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove batteries
  2. Les Paul Wireless Guitar Strummer Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Les Paul Wireless Guitar Strummer Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove void warranty sticker
    • The sticker is covering a torx screw
  3. Les Paul Wireless Guitar Strummer Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Les Paul Wireless Guitar Strummer Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Les Paul Wireless Guitar Strummer Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the 11 screws securing the back of the body using a T10 Torx screwdriver. Each screw is 1 cm long.
    • Push level, this will detach the back of the guitar from the front.
    • Carefully remove the back of the body
    • The battery pack cord is attached to both sides of the guitar, be careful not to tear it apart.
    • The neck connector may be stuck to the back so be sure to detach it before fully pulling
  4. Les Paul Wireless Guitar Strummer Replacement, Strummer: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Les Paul Wireless Guitar Strummer Replacement, Strummer: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 4 screws from the back of the strum chip using a Phillips PH1 screwdriver. each of these screws are 1.2 cm each.
    • Remove the 4 inner screws, each are 0.8 cm.
    • Make sure that when putting back together, the 4 inner screws line up with the small plastic piece underneath.
  5. Les Paul Wireless Guitar Strummer Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Les Paul Wireless Guitar Strummer Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Les Paul Wireless Guitar Strummer Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two plastic holders on the underside of the chip.
    • Pull out the the plastic piece on each side of the strummer.
    • Lift the strummer out of it's location
  6. Les Paul Wireless Guitar Strummer Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Les Paul Wireless Guitar Strummer Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Les Paul Wireless Guitar Strummer Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Take the top black cover off the strummer.
    • Slide the black rod out of the side.
    • Clean if needed.
Chris
crwdns2935283:010/18/13crwdne2935283:0
905 crwdns2915208:0crwdne2915208:0
Hi recently bought this controller again and the up strum has stopped functioning. Hoping this will fix it. Thanks
liamiley91 - crwdns2934203:0crwdne2934203:0
Did this fix your issue? Thinking about trying it.
D. Preston Peek -
Same here, i want to it try but want to know if i will be able to do it altough i’m not really good with these kind of work
Sébastien Fortuny - crwdns2934203:0crwdne2934203:0
This guitar don't have star power with up guitar? Where is sensor?
Leandro Loureiro - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 60
crwdns2942667:0crwdne2942667:0 20,882
