crwdns2956850:0crwdne2956850:0 crwdns2956756:0crwdnd2956756:0crwdne2956756:0
Lens Replacement
crwdns2869540:0crwdne2869540:0: 1.7천
5
43
145
1,720
crwdns2959984:0crwdne2959984:0: 0
crwdns2959956:0crwdne2959956:0
crwdns2955944:0crwdne2955944:0: crwdns2931273:0crwdne2931273:0
crwdns2944444:0crwdne2944444:0
crwdns2944446:0crwdne2944446:0
Lens Replacement
If the camera lens is malfunctioning, not opening or extending, or if the camera displays a system error, you may need to remove and inspect the lens, or perhaps replace it entirely. This guide shows how to replace the lens of the Panasonic Lumix TZ71.
    1. Lens Replacement, Opening the camera: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lens Replacement, Opening the camera: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lens Replacement, Opening the camera: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Turn off the camera and, for safety, remove the replacement battery.
      • Remove the four Phillips screws on the bottom.
      • Remove the two Phillips screws on the side with the door.
      • Remove the Phillips screw on the other side.
      • These screws are black and are the same length. Keep them in a safe place and keep all screws well organized.
    2. Lens Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lens Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lens Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Lift the rear bezel out. Use your fingernails or an opening pick to do so. The bezel is a bit tight.
    3. Lens Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • The back is now exposed.
      • Display
      • button board
    1. Lens Replacement, Screen: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lens Replacement, Screen: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lens Replacement, Screen: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Slide the button board down a small distance.
      • Watch out for the ribbon cable on the back at the bottom bezel.
      • Tilt the PCB up at an angle and hold it in place.
      • Flip up the black locking flap on the ZIF socket of the ribbon cable using the tip of a spudger.
      • Carefully pull the ribbon cable out with tweezers.
    2. Lens Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the button board
    3. Lens Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lens Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lens Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Slide the display slightly to the right.
      • Lift the top edge of the display slightly.
      • Open the display like a book.
      • Be careful with the ribbon cable still connecting it.
    4. Lens Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lens Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the tip of a spudger to flip up the black locking flap on the display cable socket.
      • Use tweezers to pull the ribbon cable out of the socket.
      • Remove the display.
    1. Lens Replacement, Lens: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lens Replacement, Lens: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lens Replacement, Lens: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the four Phillips screws from the copper shielding plate.
      • Keep the screws organized and ensure that each one is returned to its original place.
      • The plate is lightly adhered in the yellow-marked area. Use a spudger to begin prying it up carefully there.
      • Work your way around with the spudger and pry the plate out little by little.
      • Remove the plate.
    2. Lens Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lens Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lens Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Underneath the button board, there is also a black molded part acting as a bracket.
      • Carefully pry out the bracket with the tip of a spudger and remove it.
    3. Lens Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lens Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lens Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • The wide ribbon cable in the middle is secured with a piece of tape. Peel back the tape enough so that the cable can be unplugged.
      • Flip up the marked locking flaps on the ZIF connectors of the ribbon cables with the tip of your spudger.
      • Carefully unplug the ribbon cables one by one using tweezers. To pull out the wide ribbon cable, you can use the adhesive strip.
    4. Lens Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lens Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • The lens is almost free, but it is obstructed by the small, delicate sensor next to the viewfinder.
      • Gently pull the sensor's ribbon cable out from under the top camera cover.
      • Carefully release the ribbon cable with the sensor from its three small retaining clips.
    5. Lens Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lens Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • You can now carefully lift the lens out toward the back of the camera.
      • You can further disassemble the lens, for example, to remove dust and dirt and to clean the CCD.
      • You may be able to get the servo motors working again. If it still does not work after that, you will have to install a different lens.
Follow the steps in reverse order to reassemble your device.
VauWeh
crwdns2935283:010/19/15crwdne2935283:0
344,589 crwdns2915208:0crwdne2915208:0
crwdns2935297:0317crwdne2935297:0
Repair is War on Entropy crwdns2935289:0Repair is War on Entropycrwdne2935289:0
Community
crwdns2931471:043crwdne2931471:0
crwdns2935297:07,058crwdne2935297:0
crwdns2936753:07crwdne2936753:0 43
crwdns2936753:030crwdne2936753:0 145
crwdns2959996:0crwdne2959996:0 1,720
