Remove the two 3mm screws on the back of the device with the Phillips Screwdriver #00 bit.
Remove the 2mm screw with a Phillips #00 bit.
Using the blue opening tool or spudger, gently remove the back cover to expose the interior of the tablet.
Remove the three 2mm screws on the back of the left speaker module with the Phillips Screwdriver #00 bit.
Remove the ribbon cables connecting the boards to the other electrical components
Gently remove the left speaker module.
Replace the old left speaker module with the new left speaker module.
