Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement
  1. Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two Phillips #000 screws.
    • These screws are located behind the stand for the device.
    • Our device did not include these screws.
  2. Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a plastic iFixit opening tool to pry the edges of the back case loose by placing it in between the edge of the cover and the screen.
    • Do not immediately attempt to remove the back of the case without attempting Step three, or you risk snapping the back cover.
  3. Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the spudger to reach into the center of the device and pry off the back case by giving it a light force upwards.
  4. Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement, Back Camera: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement, Back Camera: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove one 5mm screw using the Phillips #00 Screwdriver.
  5. Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the spudger to disconnect the camera and battery from the printed circuit board by putting the spudger in between the connections and the printed circuit board and pushing the spudger up.
  6. Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove one 5mm screw with the Phillips #00 screwdriver.
  7. Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the nylon tip tweezers to push the camera out from between the power button and the kickstand.
  8. Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement, Headphone Jack: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement, Headphone Jack: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the headphone jack cover with tweezers by grabbing it and pulling directly up and away from the device.
  9. Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 3.5mm screws using the Phillips #00 Screwdriver.
  10. Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the headphone jack from the motherboard by placing the spudger in between the connections and motherboard and pushing up towards you.
    • Pull the wire towards the headphone jack to disconnect it.
  11. Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to remove the headphone jack by pulling it up and towards you.
  12. Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement, Battery: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement, Battery: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the metal spudger to push out the lock of the battery compartment by putting the metal spudger between the kickstand and the plastic and applying a force upwards.
    • Be careful as applying to much force with the metal spudger could break the plastic covering. If you feel like the plastic is going to break, change the angle at which you use the metal spudger.
    • You can only use the metal spudger on the same side as the headphone jack. Using the metal spudger on the other side will give you no results.
  13. Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the battery compartment away from the device.
    • The battery compartment is the kickstand.
  14. Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to remove the gray tape and reveal a screw at each end of the compartment.
  15. Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove one 3.5 mm screw from each end using the Phillips #00 screwdriver.
  16. Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to remove the cap from the side with the orange connector coming out of it.
    • You should hear a loud snap when you insert the tweezers in the middle of the cap and pull up.
  17. Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your hands to push the battery out towards the other side of the compartment.
    • Do not lose the cap from the other side of the compartment.
  18. Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement, Camera PCB: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 1 mm screws with a Phillips #00 Screwdriver.
  19. Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to disconnect the ribbon wire by applying a force upwards.
  20. Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to lift up the foil.
    • The foil may tear.
  21. Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tweezers to lift the black tape from the corner of the printed circuit board.
  22. Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:022crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:022crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the board 180 degrees towards you using the tweezers.
  23. Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement, Wi-Fi Module: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement, Wi-Fi Module: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the wire from the PCB by pulling it towards the edge of the headphone jack using tweezers.
  24. Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:024crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:024crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the one 5mm screw using a Phillips #00 Screwdriver.
  25. Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:025crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:025crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using tweezers remove the tape to disconnect the module by pulling it upward.
  26. Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the yellow piece of tape by pulling it upward using tweezers.
  27. Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement, Screen and Frame Assembly: crwdns2935265:027crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement, Screen and Frame Assembly: crwdns2935265:027crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement, Screen and Frame Assembly: crwdns2935265:027crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel off the ribbon wire using tweezers, and disconnect it from the motherboard.
  28. Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:028crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:028crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 1mm Phillips #00 screws.
  29. Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:029crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:029crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the wire attached to the PCB by pulling it away using tweezers.
  30. Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:030crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:030crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Desolder the wire.
    • Remove the PCB and round vibration module.
  31. Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:031crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:031crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo Yoga Tablet 10 Screen and Frame Assembly Replacement: crwdns2935265:031crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the precision tweezers to pry up the PCB along with the round vibration module from its bottom corner lifting it upwards .
    • The precision tweezers are sharp and may damage the PCB or vibration module.
Juan Benjamin
crwdns2935283:001/24/19crwdne2935283:0
490 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S2-G6, White Winter 2019 crwdns2935289:0Cal Poly, Team S2-G6, White Winter 2019crwdne2935289:0
CPSU-WHITE-W19S2G6
crwdns2942667:0crwdne2942667:0 1,783
