Lenovo Yoga Tab 3 10 Wifi Module Replacement
  1. Lenovo Yoga Tab 3 10 Wifi Module Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the built-in kickstand.
  2. Lenovo Yoga Tab 3 10 Wifi Module Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo Yoga Tab 3 10 Wifi Module Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo Yoga Tab 3 10 Wifi Module Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the sticker located directly under the the built-in kickstand to reveal two 0.75 mm screws.
    • Remove the microSD card slot cover. Remove any microSD card (if inserted).
    • Using a Phillips head screwdriver, remove the three 0.75 mm screws.
  3. Lenovo Yoga Tab 3 10 Wifi Module Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo Yoga Tab 3 10 Wifi Module Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo Yoga Tab 3 10 Wifi Module Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Orient the device so the screen is facing you.
    • Carefully insert the spudger along the seam between the screen and back cover and gently separate the back cover from the device frame.
    • Continue to detach the backplate from the frame by moving the spudger around the perimeter.
    • Some force will be required to detach the small plastic braces securing the backplate to the device.
  4. Lenovo Yoga Tab 3 10 Wifi Module Replacement, Wifi Module: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga Tab 3 10 Wifi Module Replacement, Wifi Module: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the nylon spudger to gently lift the foil cover of the wifi model.
  5. Lenovo Yoga Tab 3 10 Wifi Module Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use tweezers to gently lift the gold tape located above the copper foil.
  6. Lenovo Yoga Tab 3 10 Wifi Module Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the plastic spudger to disconnect the wifi module connector from the motherboard.
  7. Lenovo Yoga Tab 3 10 Wifi Module Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga Tab 3 10 Wifi Module Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully lift the wifi module from the device.
Phanudej
crwdns2935283:002/20/17crwdne2935283:0
1,190 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S3-G2, Sullivan Spring 2017 crwdns2935289:0USF Tampa, Team S3-G2, Sullivan Spring 2017crwdne2935289:0
USFT-SULLIVAN-S17S3G2
crwdns2935297:018crwdne2935297:0
where can i buy this type of module?
rebeca rackolavsci - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 3,899
