Open the built-in kickstand.
Remove the sticker located directly under the the built-in kickstand to reveal two 0.75 mm screws.
Remove the microSD card slot cover. Remove any microSD card (if inserted).
Using a Phillips head screwdriver, remove the three 0.75 mm screws.
On 3 plus model the third screw is not under microSD card but rather under a small sticker on the right side. Plus has longer battery.
on the Tab 3 plus , the third screw is not under the sd card but a little further over under another sticker and is painted white
Orient the device so the screen is facing you.
Carefully insert the spudger along the seam between the screen and back cover and gently separate the back cover from the device frame.
Continue to detach the backplate from the frame by moving the spudger around the perimeter.
On some models there is glue pad under the sim/sdcard tray.
Ein Hinweis auf den Federrahmen an der Kamera wäre nützlich. Er ist sehr empfindlich. Ich habe ihn beim Öffnen zerstört und jetzt stellt die Kamera nicht mehr scharf.
Hallo Thomas, tut mir leid, dass deine Kamera nicht mehr schart stellt. Aber die Anleitungen funktionieren wie Wikipedia: Wenn du mehr Infos hast, stelle sie gern allen anderen zur Verfügung!
(at least on the Plus model) the most difficult plastic clips are near the micro-SD/SIM. So it is easier to release the other side, where the camera not is. or pull the casing "down" towards the battery/stand.
Remove the 3 screws from the auxiliary port cover.
Use the spudger to gently push the auxiliary module out of the way.
Remove the detachable plastic latch located in front of the hinge.
Use a spudger to gently remove the hinge.
Carefully lift the kickstand away from the frame.
Use the pointed end of a spudger to push in the camera's locking mechanism.
Upon releasing the camera lock lift the camera out and locate the three screws.
Use a J000 Philips screwdriver to remove the three screws.
Remove the camera cover that seals the camera case.
Remove the camera from the shell.
Thanks for describing in details with bit and peaces very neatly and clearly. I fix the problem of my Lenovo Yoga 3 with help of this. Great job you have done.. keep it up… Sisira
