Lenovo Yoga Tab 3 10 Camera Replacement
  1. Lenovo Yoga Tab 3 10 Camera Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the built-in kickstand.
  2. Lenovo Yoga Tab 3 10 Camera Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo Yoga Tab 3 10 Camera Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo Yoga Tab 3 10 Camera Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the sticker located directly under the the built-in kickstand to reveal two 0.75 mm screws.
    • Remove the microSD card slot cover. Remove any microSD card (if inserted).
    • Using a Phillips head screwdriver, remove the three 0.75 mm screws.
    On 3 plus model the third screw is not under microSD card but rather under a small sticker on the right side. Plus has longer battery.
    George - crwdns2934203:0crwdne2934203:0
    on the Tab 3 plus , the third screw is not under the sd card but a little further over under another sticker and is painted white
    dan o brien - crwdns2934203:0crwdne2934203:0
  3. Lenovo Yoga Tab 3 10 Camera Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo Yoga Tab 3 10 Camera Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo Yoga Tab 3 10 Camera Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Orient the device so the screen is facing you.
    • Carefully insert the spudger along the seam between the screen and back cover and gently separate the back cover from the device frame.
    • Continue to detach the backplate from the frame by moving the spudger around the perimeter.
    • Some force will be required to detach the small plastic braces securing the backplate to the device.
    On some models there is glue pad under the sim/sdcard tray.
    Ervins Stepanovs - crwdns2934203:0crwdne2934203:0
    Ein Hinweis auf den Federrahmen an der Kamera wäre nützlich. Er ist sehr empfindlich. Ich habe ihn beim Öffnen zerstört und jetzt stellt die Kamera nicht mehr scharf.
    Thomas Spieker - crwdns2934203:0crwdne2934203:0
    Hallo Thomas, tut mir leid, dass deine Kamera nicht mehr schart stellt. Aber die Anleitungen funktionieren wie Wikipedia: Wenn du mehr Infos hast, stelle sie gern allen anderen zur Verfügung!
    Fabian Neidhardt -
    (at least on the Plus model) the most difficult plastic clips are near the micro-SD/SIM. So it is easier to release the other side, where the camera not is. or pull the casing "down" towards the battery/stand.
    Hans Wurst - crwdns2934203:0crwdne2934203:0
  4. Lenovo Yoga Tab 3 10 Camera Replacement, Camera: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo Yoga Tab 3 10 Camera Replacement, Camera: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo Yoga Tab 3 10 Camera Replacement, Camera: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 3 screws from the auxiliary port cover.
    • Use the spudger to gently push the auxiliary module out of the way.
    • Remove the detachable plastic latch located in front of the hinge.
  5. Lenovo Yoga Tab 3 10 Camera Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to gently remove the hinge.
  6. Lenovo Yoga Tab 3 10 Camera Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift the kickstand away from the frame.
    • The battery is located inside of the kickstand. Ensure proper handling and care.
  7. Lenovo Yoga Tab 3 10 Camera Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga Tab 3 10 Camera Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of a spudger to push in the camera's locking mechanism.
    • Upon releasing the camera lock lift the camera out and locate the three screws.
  8. Lenovo Yoga Tab 3 10 Camera Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo Yoga Tab 3 10 Camera Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo Yoga Tab 3 10 Camera Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a J000 Philips screwdriver to remove the three screws.
    • Remove the camera cover that seals the camera case.
    • Remove the camera from the shell.
  9. Lenovo Yoga Tab 3 10 Camera Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the camera from its casing.
Phanudej
crwdns2935283:002/20/17crwdne2935283:0
1 190 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S3-G2, Sullivan Spring 2017 crwdns2935289:0USF Tampa, Team S3-G2, Sullivan Spring 2017crwdne2935289:0
USFT-SULLIVAN-S17S3G2
crwdns2935297:018crwdne2935297:0
Thanks for describing in details with bit and peaces very neatly and clearly. I fix the problem of my Lenovo Yoga 3 with help of this. Great job you have done.. keep it up… Sisira
Sisira Kumara - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 4,306
