If you are having trouble with your Lenovo Yoga C930-13IKB touch pad or your touch pad is damaged, this guide will help you replace it. First, check out this troubleshooting guide to try other ways to fix a faulty touch pad before replacing it.
To access the touch pad, you will need to remove the back cover and the battery, which is outlined below. Then the back of the touch pad will be exposed and you can take it out once all the fasteners have been removed.
Flip the device over so that the underside is facing up.
Remove the six 3.5 mm T5 Torx screws.
Pry off the back cover using the plastic opening tool.
Loosen the back cover in multiple spots using the opening tool, then remove the whole back.
Carefully lift the cover off with your hands.
Unplug the battery from the motherboard by pinching the cables with your fingers and tugging out with force.
Unscrew the four 3mm screws with a Phillips screwdriver.
Use your fingers to pry up the clear plastic pull-tab for one of the stretch release adhesives.
Grasp the pull-tab and slowly pull away from the battery at a shallow angle. The adhesive strip will stretch to many times its length and slowly release from underneath the battery.
Repeat the procedure for the second strip on the opposite side of the battery.
Remove the battery with your hands.
Unscrew the four 2 mm screws with a Phillips #00 screwdriver.
Carefully pull out the small electrical wire from the back of the touch pad.
Lift up the touch pad.
Slide the touch pad out of the laptop.
