Flip the device over so that the underside is facing up.
Remove the six 3.5 mm T5 Torx screws.
Pry off the back cover using the plastic opening tool.
Loosen the back cover in multiple spots using the opening tool, then remove the whole back.
Carefully lift the cover off with your hands.
Remove the four 3 mm Phillips #0 screws from the fan assembly.
Remove the four 2 mm Phillips #00 screws from the fans themselves.
Unscrew the three 3 mm Phillips #0 screws on the heatsink.
Use a plastic opening tool to remove the two small, white power cable connectors for each of the two fans.
Gently lift the fan assembly out of the laptop.
To reassemble your device, follow these instructions in reverse order. Remember to apply fresh thermal paste to the heatsink during reassembly.
