Lenovo Yoga C640-13IML Battery Replacement
  1. Lenovo Yoga C640-13IML Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Torx T4 screwdriver to remove the six 4.60 mm screws securing the bottom panel.
    • Keep the screws organized to make reassembly easier.
  2. Lenovo Yoga C640-13IML Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert a plastic spudger or opening pick into the seam between the bottom panel and the chassis.
    • Gently slide the tool along the edges to release the internal clips and lift the panel off.
    • Go slowly to avoid cracking or snapping the plastic clips.
  3. Lenovo Yoga C640-13IML Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five 4.60 mm Phillips #0 screws securing the battery to the chassis.
    • Keep these screws separate from the bottom panel screws—they’re different sizes.
  4. Lenovo Yoga C640-13IML Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga C640-13IML Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to lift and unclip the outer edges of the connector. You may need to use your fingers to pull the connector completely out of its socket.
    • Do not pull on the battery wires—only lift from the plastic base of the connector using a spudger.
    • To reconnect the cable, carefully position the connector over its socket and press straight down—the connector should snap into place without much force. If you're having trouble, the connector is most likely misaligned. Reposition it and try again.
    • Lift the battery out of the laptop.
To reassemble your device, follow these instructions in reverse order. For optimal performance, calibrate your newly installed battery after completing this guide.
Cece
crwdns2935283:004/14/25crwdne2935283:0
313 crwdns2915208:0crwdne2915208:0
Linn Benton Community College, Team 1-1, Karnes Spring 2025 crwdns2935289:0Linn Benton Community College, Team 1-1, Karnes Spring 2025crwdne2935289:0
LBCC-KARNES-S25S1G1
crwdns2936753:030crwdne2936753:0 53
crwdns2942667:0crwdne2942667:0 102
