This guide will show how to replace the motherboard in the Lenovo Yoga 920-13IKB.
Remove the ten 5mm Torx T5 screws on the back cover to loosen the back cover.
Slide the iFixit Opening Tool under the back cover to lift it up.
Pull up on the cover with your hand to release the tab holding the center of the cover in place.
Die Mitte der unteren Abdeckung wird von zwei Plastiknoppen am Gerät gehalten. Wenn die Schrauben gelöst sind, mit beiden Händen unter die Abdeckung greifen und nach oben gerade wegziehen.
The center of the bottom cover is held to the device by a two pronged plastic clip. When the screws are loosened, I reached under to the center of the cover with a dinner knife and pried straight up.
Remove the twelve 5mm Phillips #00 screws to loosen the motherboard.
Flip up the ten flat connectors holding the motherboard using the iFixit Opening Tool to free the motherboard.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Pull out the ribbon cables from the opened connectors using the iFixit Tweezers to free up the motherboard.
Disconnect the battery by pulling the ribbon wire grouping out of the top of the motherboard.
Disconnect the red and black wire from the motherboard using the iFixit Tweezers.
Hi there. Could this step be further clarified, please? Does the small rectangular plastic component detach from the board?
I ended up simply unscrewing the speaker module that these Red and black cables connect to and removing that along with the motherboard.
Lift the motherboard up parallel to the hinge of the device.
Gently pull away from the port cutouts of the USB-C and audio jack to remove the motherboard from the device casing.
Disconnect the green AC card plugged into the motherboard by pulling it out with your hands.
Flip the motherboard over to access the back side.
Remove four 3mm JIS #00 screws with the screwdriver.
Remove one 3mm Phillips #00 screw with the screwdriver.
Separate the fans from the motherboard to isolate it for replacement.
crwdns2935229:08crwdne2935229:0
I need to fix my touchpad. It moves and clicks, but when i press down to click it does not work. It will only select thing by tapping, not clicking.
Hi. I gave this guide a look, as I'm attempting to upgrade my SSD. I got things a bit out of order and pulled out one of the ribbon cables in step 5, before flipping up the tabs in step 4. I then gave up and put the ribbon cable back and replaced the screws. However, now the machine won't start. I can't see how removing and then replacing the ribbon cable might cause this. Does anyone have any ideas?
False alarm! I must not have put a ribbon cable all the way back into its socket. After another check it all went back together and started without issue. Great guide. Thanks!
After removing the fan, do you need to do anything with the thermal paste? Remove it, replace it when you go to put the fan back together?
It depends on the quality of the thermal paste and how it has aged - If it’s still seemingly ‘wet’ (don’t touch it, just observe) then it’s likely fine to leave, but if it instead is ‘dry’ or visibly cracked then you should replace it. First, clean the CPU carefully with isopropyl alcohol and a lint-free towel. Then add an appropriate amount of thermal paste and reattach the heatsink assembly. Be sure to apply even force to each screw little-by-little when screwing it back in.
When in doubt, replace the thermal paste.
Chris -
Lenovo Yoga 9xx series designed to fail. Most common fault is the motherboard power, I have had five Yogas ,Good Computer when working. But when they fail not worth fixing. Limited upgrade options. Best go look elsewhere. average to low quality
