Lenovo Yoga 910-13IKB Fingerprint Reader Replacement
  1. Lenovo Yoga 910-13IKB Fingerprint Reader Replacement, Bottom Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga 910-13IKB Fingerprint Reader Replacement, Bottom Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Turn the laptop over and remove the ten Torx T5 screws along the perimeter of the bottom panel.
    • Remove the panel.
  2. Lenovo Yoga 910-13IKB Fingerprint Reader Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the four M2 x 1.7 mm screws securing the battery to the laptop.
    • Remove the battery.
  3. Lenovo Yoga 910-13IKB Fingerprint Reader Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six Phillips screws that attach the trackpad to the device.
    • Use a spudger to disconnect the ribbon cable connector from the trackpad.
    • Remove the trackpad using a spudger.
  4. Lenovo Yoga 910-13IKB Fingerprint Reader Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove six screws attached to the USB ports on both sides of the device.
    • Detach both ribbon cables attached to each USB port with a spudger, then detach the USB ports.
  5. Lenovo Yoga 910-13IKB Fingerprint Reader Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga 910-13IKB Fingerprint Reader Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a small Phillips screwdriver to remove all single screw securing the SSD stick to the motherboard.
    • Slide the SSD stick from the port on the motherboard.
  6. Lenovo Yoga 910-13IKB Fingerprint Reader Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo Yoga 910-13IKB Fingerprint Reader Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo Yoga 910-13IKB Fingerprint Reader Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a small Phillips screwdriver to remove four screws from the fans.
    • Remove the back connector strip using a spudger to pry it off of the device.
    • Remove the fans.
    • Now, only the bottom panel should remain.
  7. Lenovo Yoga 910-13IKB Fingerprint Reader Replacement, Battery: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 3 mm Phillips #0 screws holding the battery in place.
  8. Lenovo Yoga 910-13IKB Fingerprint Reader Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo Yoga 910-13IKB Fingerprint Reader Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo Yoga 910-13IKB Fingerprint Reader Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery. The spudger tool may be needed to lift the flap seal.
    • Pull parallel to the battery, not straight up.
    • Pull evenly on the width of the cable so that no individual wire is overly strained.
    • Lift the battery out.
  9. Lenovo Yoga 910-13IKB Fingerprint Reader Replacement, Fingerprint Reader: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga 910-13IKB Fingerprint Reader Replacement, Fingerprint Reader: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the one 3mm JIS #00 screw on the right side of the silver component.
  10. Lenovo Yoga 910-13IKB Fingerprint Reader Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga 910-13IKB Fingerprint Reader Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull up on the ribbon cable to detach it from the metal housing.
  11. Lenovo Yoga 910-13IKB Fingerprint Reader Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the metal housing out and set it aside. This component holds the reader in place.
    • The left side of the component is tucked under the lip of the computer, so lift from the right side of the component.
  12. Lenovo Yoga 910-13IKB Fingerprint Reader Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the fingerprint reader from its place.
Nikki Sorfleet
crwdns2935283:001/23/20crwdne2935283:0
175 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S1-G5, White Winter 2020 crwdns2935289:0Cal Poly, Team S1-G5, White Winter 2020crwdne2935289:0
CPSU-WHITE-W20S1G5
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 489
