This guide shows how to properly remove the bottom case.
Remove seven Torx T5 short screws.
Remove three Torx T5 long screws.
crwdns2935267:0crwdne2935267:0iFixit Opening Tool$1.99
Starting from the USB port, use your opening tool to gently pry up the case.
Pry along the laptop in the order shown by the arrows.
Lift the case from the bottom side. NOT the side with the hinges.
Once you feel resistance, gently pull the case towards you. (away from the hinges.)
Remove the case.
crwdns2935229:05crwdne2935229:0
Can’t seem to find information about this but why should I discharge the laptop to 25% before I do this?
I bought a new wifi card that I will put in.
You should discharge the laptop to minimize the danger of fire and exploding battery if accidentally damages or short circuit occur during handling the accumulator. Fully charged accumulators will react more violently when short-circuited or damaged.
