Solid state drives are known to fail occasionally, but this doesn't mean you have to do away with your laptop entirely. Replacing a bad drive is as simple as removing the battery and a single screw. Failure can be caused by heat, voltage fluctuation, and age.
Remove the ten 3.3 mm T5 screws from the base cover.
Slide an opening tool between the base and back cover and work your way around the entire device to release the back cover.
Wow, this is extremely difficult. Wondering why Lenovo didn’t provide small grooves to simplify this process. This is my first and last time purchasing a Lenovo. I’ve experienced so many issue with this laptop
Remove the four 3.5 mm screws around the battery using a Phillips #1 screwdriver.
The ones in mine were a Philips #1
The screws securing my battery were also PH1. Be careful as it would be extremely easy to strip the heads on these screws using the incorrect size.
Thanks! I’ll update the step to reflect this.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Disconnect the battery by pulling its cable away from the hinge with a pair of tweezers or your fingers.
There is no latch or anything. Just pull it out gently towards the battery.
I had to put a bit of elbow grease and patience into this step. Looking at the replacement battery as reference help to understand what would work best
This step made me nervous! I wasn't sure how much elbow grease to use. It took a good firm horizontal yank, holding the cord near the plug. It's probably not a good idea to yank it by grasping the battery.
Remove the one JIS 1 screw holding the solid state drive in place.
Gently pull the solid state drive out and up to remove it from the connector.
Just a head up, The What you need area of this page shows crucial MX500 sata hard drives as being compatiable when it is not. Has to be M.2 SSD.
No need to remove battery. No need for tweezers.
¿Son Vdes. conscientes de que están haciendo una mala traducción del inglés? Están traduciendo “remove”, que en castellano se traduce por retirar, como remover, que en inglés se traduce por “stir”. No aconsejo remover los tornillos ni las baterías.
stuart.medina - crwdns2934203:0crwdne2934203:0
Be cognizant of which screws come from which locations. I did not notice that three of the screws were longer than the others. I ended up reinstalling mine along the hinge side of the back cover.
jcorrell68 - crwdns2934203:0crwdne2934203:0
Thanks for the tip! I’ll add that into the guide.
Arthur Shi -
