Use a Torx T4 screwdriver to unscrew the nine 5 mm screws holding the cover in place.
Use a Torx T4 screwdriver to unscrew the 8 mm screw in the center.
Use the plastic opening tool to pry the cover up and away from the laptop, starting at one end and working your way around the cover.
Use blue plastic opening tool to pry the ram cover loose. Carefully lift up the ram cover and remove it from the laptop.
Locate the ram hold downs.
Push outwards on the hold downs to release the RAM.
una pregunta, cuantas ranuras de memoria RAM tiene?
One question, how many RAM slots does it have? -
Remove the RAM by pulling away from the RAM socket.
crwdns2935229:014crwdne2935229:0
crwdns2947412:05crwdne2947412:0
Hi, can the RAM be expandable and what is the highest RAM expansion this lenovo YOGA 710-14IKB can take?
Hi Victoria, I replaced the 8GB RAM stick with a single 16GB RAM stick and this does work!
It has 1 RAM slot
Una pregunta, si tengo una lenovo Yoga 520-14IKB y en el administrador de tareas, en la parte de rendimiento me aparece 1 de 2 ranuras usadas de memoria, ¿Dónde se encuentra la segunda ranura? (la única ram que tiene es la que está en el módulo DIMM)
