Lenovo Yoga 710-14IKB RAM Replacement
  1. Lenovo Yoga 710-14IKB RAM Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Ensure your device is completely OFF before starting this guide.
    • Use a Torx T4 screwdriver to unscrew the nine 5 mm screws holding the cover in place.
    • Use a Torx T4 screwdriver to unscrew the 8 mm screw in the center.
    • When, reassembling, make sure not to tighten the screws too much or you may risk cracking the plastic cover.
  2. Lenovo Yoga 710-14IKB RAM Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo Yoga 710-14IKB RAM Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo Yoga 710-14IKB RAM Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the plastic opening tool to pry the cover up and away from the laptop, starting at one end and working your way around the cover.
    • The cover is large and flat and made of thin plastic. It cracks easily, so make sure not to pry too hard.
  3. Lenovo Yoga 710-14IKB RAM Replacement, RAM: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga 710-14IKB RAM Replacement, RAM: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use blue plastic opening tool to pry the ram cover loose. Carefully lift up the ram cover and remove it from the laptop.
  4. Lenovo Yoga 710-14IKB RAM Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga 710-14IKB RAM Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the ram hold downs.
    • Push outwards on the hold downs to release the RAM.
    una pregunta, cuantas ranuras de memoria RAM tiene?
    One question, how many RAM slots does it have?
    andres arce - crwdns2934203:0crwdne2934203:0
  5. Lenovo Yoga 710-14IKB RAM Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga 710-14IKB RAM Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the RAM by pulling away from the RAM socket.
    Thanks, updated to 16GB, works fine!!!
    Roman Hrytsiuk - crwdns2934203:0crwdne2934203:0
crwdns2935229:014crwdne2935229:0
Grant Doerksen
crwdns2935283:004/17/17crwdne2935283:0
1,011 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S14-G5, Banghart Spring 2017 crwdns2935289:0Cal Poly, Team S14-G5, Banghart Spring 2017crwdne2935289:0
CPSU-BANGHART-S17S14G5
crwdns2935297:027crwdne2935297:0
crwdns2947412:05crwdne2947412:0
Hi, can the RAM be expandable and what is the highest RAM expansion this lenovo YOGA 710-14IKB can take?
victoria - crwdns2934203:0crwdne2934203:0
Hi Victoria, I replaced the 8GB RAM stick with a single 16GB RAM stick and this does work!
Johannes de Wit -
It has 1 RAM slot
Lil Youman -
Una pregunta, si tengo una lenovo Yoga 520-14IKB y en el administrador de tareas, en la parte de rendimiento me aparece 1 de 2 ranuras usadas de memoria, ¿Dónde se encuentra la segunda ranura? (la única ram que tiene es la que está en el módulo DIMM)
Mauricio Oviedo - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 61
crwdns2942667:0crwdne2942667:0 7,355
