Lenovo Yoga 700-11ISK Wireless Card Replacement
  1. Lenovo Yoga 700-11ISK Wireless Card Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga 700-11ISK Wireless Card Replacement, Back Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip your device so that the bottom panel is facing up.
    • Remove the eleven 5mm Torx T5 screws from the back panel.
  2. Lenovo Yoga 700-11ISK Wireless Card Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to unclip clips on the front and near the USB ports on each side
    • Lift the back panel off
  3. Lenovo Yoga 700-11ISK Wireless Card Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 3mm Phillips #1 screws holding the battery to the laptop chassis.
    • Disconnect the battery from the IO board by holding the connector by the sides and gently pulling the connector out.
  4. Lenovo Yoga 700-11ISK Wireless Card Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the battery from the laptop.
    • Make sure that all wires still connected to the laptop are out of the way and not pulled out with the battery.
  5. Lenovo Yoga 700-11ISK Wireless Card Replacement, Wireless Card: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo Yoga 700-11ISK Wireless Card Replacement, Wireless Card: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo Yoga 700-11ISK Wireless Card Replacement, Wireless Card: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the laptop with the LCD facing down so that the hinges face opposite you.
    • Disconnect both ends of the two blue ZIF (zero insertion force) connectors in the upper left corner and by gently flipping the black tabs on the connector and pulling up and away from both ends of the connectors.
    • Do not pull on the blue tab of the cable without lifting up the black tabs on the connectors. The cable should slide in and out effortlessly. If there is resistance when pulling the cable, double check the black tabs.
  6. Lenovo Yoga 700-11ISK Wireless Card Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the black and white wireless LAN cables in the upper left corner by gently pulling upwards.
    • To reinstall a wireless LAN card, note that the black cable goes to the MAIN jack, and the white to the AUX jack.
  7. Lenovo Yoga 700-11ISK Wireless Card Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga 700-11ISK Wireless Card Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the one 2mm Phillips #1 screw.
    • Remove the card by pulling to the left and up.
Gabrielle Bullen
crwdns2935283:010/06/16crwdne2935283:0
372 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 15-6, Livingston Fall 2016 crwdns2935289:0Cal Poly, Team 15-6, Livingston Fall 2016crwdne2935289:0
CPSU-LIVINGSTON-F16S15G6
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 1,299
