Lenovo Yoga 700-11ISK LCD Replacement
  1. Lenovo Yoga 700-11ISK LCD Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga 700-11ISK LCD Replacement, Back Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip your device so that the bottom panel is facing up.
    • Remove the eleven 5mm Torx T5 screws from the back panel.
    Your list of t7 screwdriver costed me to order a wrong one.
    it should be T5 but the ad listed T7!!!!!
    it is frustrating.
    Remy Williams - crwdns2934203:0crwdne2934203:0
  2. Lenovo Yoga 700-11ISK LCD Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to unclip clips on the front and near the USB ports on each side
    • Lift the back panel off
    where can I buy the back panel?
    malinthae - crwdns2934203:0crwdne2934203:0
    The back panel is also held on by a few clips, but a spudger can come in handy here.
    alan - crwdns2934203:0crwdne2934203:0
    The clips on the sides are between the USB ports on the left side, and just in front of the USB port on the right.
  3. Lenovo Yoga 700-11ISK LCD Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 3mm Phillips #1 screws holding the battery to the laptop chassis.
    • Disconnect the battery from the IO board by holding the connector by the sides and gently pulling the connector out.
    The left screw is hidden below a tamper-evident sticker.
    There is a plastic channel along the right edge of the battery that has wires running through it to a different board. It works best if the other connector next to the battery connector is unclipped and those wires are taken out of that channel.
  4. Lenovo Yoga 700-11ISK LCD Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the battery from the laptop.
    • Make sure that all wires still connected to the laptop are out of the way and not pulled out with the battery.
    Along the right edge of the battery, there is a channel with wires running to a connector next to the battery connector. It works better to disconnect that connector too and fold the battery to the right.
    Re: the above “fold the battery to the right” comment: If all you’re doing is replacing the touchpad, the “fold over” method works as it keeps the wires in the channel. If you’re replacing the battery or whatever those wires connect to, obviously that won’t work.
  5. Lenovo Yoga 700-11ISK LCD Replacement, LCD: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo Yoga 700-11ISK LCD Replacement, LCD: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo Yoga 700-11ISK LCD Replacement, LCD: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the following cables attaching the LCD to the laptop:
    • Touchscreen cable
    • EDP cable
  6. Lenovo Yoga 700-11ISK LCD Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo Yoga 700-11ISK LCD Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo Yoga 700-11ISK LCD Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the laptop with the LCD facing down so that the hinges face opposite you.
    • Disconnect both ends of the two blue ZIF (zero insertion force) connectors in the upper left corner by gently flipping the black tabs on the connector and pulling up and away from both ends of the connectors.
    • Do not pull on the blue tab of the cable without lifting up the black tabs on the connectors. The cable should slide in and out effortlessly. If there is resistance when pulling the cable, double check the black tabs.
  7. Lenovo Yoga 700-11ISK LCD Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the black and white wireless LAN cables in the upper left corner by gently pulling upwards.
    • To reinstall a wireless LAN card, note that the black cable goes to the MAIN jack, and the white to the AUX jack.
  8. Lenovo Yoga 700-11ISK LCD Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo Yoga 700-11ISK LCD Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo Yoga 700-11ISK LCD Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the six 5mm Phillips #1 screws located in the top left and right corners to free the hinges.
    • Fully extend the hinges by prying upwards.
  9. Lenovo Yoga 700-11ISK LCD Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo Yoga 700-11ISK LCD Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo Yoga 700-11ISK LCD Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the base from the LCD by lifting it upwards.
    • Flip the LCD so that the hinges face you and the screen faces upwards.
    • Remove the two LCD bezel screw pads located in the bottom left and right outer corners by pulling them up and out.
    • Remove the two 4.4 mm Phillips #1 screws located under the screw pads.
    • Pry the two side hinge covers with a plastic spudger and pull them up and away from the LCD.
  10. Lenovo Yoga 700-11ISK LCD Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga 700-11ISK LCD Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the LCD hinge cover by gently prying the pieces with a plastic spudger and lifting the hinge cover up and out.
  11. Lenovo Yoga 700-11ISK LCD Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo Yoga 700-11ISK LCD Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo Yoga 700-11ISK LCD Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the white MIC board connecter located near the center of the LCD bezel by pulling it out to the left.
    • Flip the hinges up and remove the hinge rubbers by pulling the wires out and away from the hinges.
  12. Lenovo Yoga 700-11ISK LCD Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga 700-11ISK LCD Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the LCD by carefully pulling away from the hinges and upwards.
Gabrielle Bullen
crwdns2935283:010/06/16crwdne2935283:0
372 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 15-6, Livingston Fall 2016 crwdns2935289:0Cal Poly, Team 15-6, Livingston Fall 2016crwdne2935289:0
CPSU-LIVINGSTON-F16S15G6
Just what I needed to replace the adhesive tape on my screen. Thanks!
Stephen - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 8,797
