Remove the ten T5 screws fastening the back case.
Slide a plastic opening tool underneath the back case near the screen hinges. Gently pry up on either side.
Slide the opening tool underneath the back case next to the middle screw hole at either side of the case. Gently pry up.
Remove the back case by pulling up near the screen hinges and lifting diagonally away from the laptop.
Remove the four M2 screws fastening the battery to the case
Gently pull out the battery and put it aside.
Remove the screw holding the WiFi card
Pull out the card and place it aside.
