Lenovo Yoga 530-14IKB Keyboard Replacement
    • Power off the laptop and place it facedown on a non-scratching surface
    • Remove the ten T5 screws fastening the back case.
    • Slide a plastic opening tool underneath the back case near the screen hinges. Gently pry up on either side.
    • Slide the opening tool underneath the back case next to the middle screw hole at either side of the case. Gently pry up.
    • You may hear popping sounds as the tabs securing the case release. This is normal. If the case does not move, try prying at a different angle/position.
    • Remove the back case by pulling up near the screen hinges and lifting diagonally away from the laptop.
    • Go slowly to avoid breaking any connecting tabs.
    • Be careful not to touch the other components during this step.
    • Disconnect the battery.
    • Remove the four M2 screws fastening the battery to the case
    • Gently pull out the battery and put it aside.
    • Remove the screw holding the WiFi card
    • Pull out the card and place it aside.
possumdoe
crwdns2935283:009/19/23crwdne2935283:0
133 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 37
crwdns2942667:0crwdne2942667:0 779
