Lenovo Yoga 3 14 Motherboard Replacement
  1. Lenovo Yoga 3 14 Motherboard Replacement, Back Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the eleven 6mm T5 Torx screws from the back case.
  2. Lenovo Yoga 3 14 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo Yoga 3 14 Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo Yoga 3 14 Motherboard Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the plastic opening tool into the long side of the case backing and slide it the entire length of the laptop.
    • Gently lift the backing off the laptop.
  3. Lenovo Yoga 3 14 Motherboard Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 3mm PH#0 screws surrounding the battery.
  4. Lenovo Yoga 3 14 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo Yoga 3 14 Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo Yoga 3 14 Motherboard Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently lift the battery and use the plastic opening tool to remove the battery's connection to the laptop.
  5. Lenovo Yoga 3 14 Motherboard Replacement, Cooling Fan: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga 3 14 Motherboard Replacement, Cooling Fan: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 3mm screws using the PH#0 screwdriver head.
    • Unscrew the three 4mm screws using PH#1 (the larger screws do not come off the are attached to the housing unit of the cooling fan).
  6. Lenovo Yoga 3 14 Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo Yoga 3 14 Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo Yoga 3 14 Motherboard Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers to disconnect the fan.
    • Unwrap the white and black wires from around the fan case.
  7. Lenovo Yoga 3 14 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the fan out of the laptop.
    On reassemble I guess you need to clean up the heatsink and processor, and renew the heatsink paste, otherwise you could well be making things a lot worse.
    Philip Le Riche - crwdns2934203:0crwdne2934203:0
  8. Lenovo Yoga 3 14 Motherboard Replacement, Motherboard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the three 3mm screws from the bottom right hinge using a PH0 screwdriver.
    • Remove the one 4mm screw that connects the hinge to the motherboard.
    Step 8a: photo shows location of three 3mm screws. However, only 2 screws are present. The hole in the lower right of the image receives one of the housing cover screws.
    Gary Hughes - crwdns2934203:0crwdne2934203:0
  9. Lenovo Yoga 3 14 Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga 3 14 Motherboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the tweezers, disconnect the white and black cables connecting the motherboard to the screen.
  10. Lenovo Yoga 3 14 Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga 3 14 Motherboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using tweezers, disconnect the second cable connecting the screen to the motherboard.
    To disconnect this cable, lift straight up.
  11. Lenovo Yoga 3 14 Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga 3 14 Motherboard Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the plastic clip connecting the USB port cable to the motherboard.
    • Gently use tweezers to remove the cable.
  12. Lenovo Yoga 3 14 Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga 3 14 Motherboard Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using tweezers, undo the plastic clip holding the ribbon in place and gently pull the ribbon to remove it.
  13. Lenovo Yoga 3 14 Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga 3 14 Motherboard Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift the clip holding down the blue ribbon connection the touch pad to the motherboard. Use tweezers to disconnect the ribbon.
  14. Lenovo Yoga 3 14 Motherboard Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga 3 14 Motherboard Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Undo the clips holding the blue and brown ribbon to the motherboard. Use tweezers to gently remove both ribbons.
    does anybody know the name of the connector of the brown cable? in my case it broke
    Dalibor Jaklin - crwdns2934203:0crwdne2934203:0
  15. Lenovo Yoga 3 14 Motherboard Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place one hand on the hard drive and gently gripping the black connector, pull it away from the hard drive to disconnect.
    • Our laptop did not have the hard drive with it, but this is where it would be located.
    Seems like it might be better to slide out the blue ribbon connector.
    Agreed, with hard drive fitted it is easier to remove the blue end.
    Stephen Adams - crwdns2934203:0crwdne2934203:0
  16. Lenovo Yoga 3 14 Motherboard Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift the motherboard away from the laptop.
Mohammed
crwdns2935283:009/28/16crwdne2935283:0
USF Tampa, Team 3-2, Passmore Fall 2016 crwdns2935289:0USF Tampa, Team 3-2, Passmore Fall 2016crwdne2935289:0
USFT-PASSMORE-F16S3G2
crwdns2947412:07crwdne2947412:0
Hi, Is the i7 motherboard version is the same size ,ports and screws as i5 ??
Is there any issue if i replace my old i5 with i7 ? ignoring battery performance.
please advice.
ahmedbazy - crwdns2934203:0crwdne2934203:0
Did you replace your i5 motherboard for an i7? Was everything ok?
I’m thinking about doing the same…
rsoares -
One assumes new thermal paste is required when re-attach the van?
Chris Rivers - crwdns2934203:0crwdne2934203:0
Do you mean the fan? If I remember correctly, there was no thermal paste attaching the fan to the motherboard or the surrounding components. It was just housed within the casing attached via screws as shown in the images.
Ryan Bump -
Ryan,
Thank you for your reply.
Yes I mean the fan, sorry. Step 5 you remove the 3 screws for what I assume is the heat sink. I was asking about that as it looks like the the processor is under there and seems to have thermal paste on the top.
Chris Rivers -
Chris,
I see what you mean. It's on that left side of the housing. It does appear there is thermal paste there.
I'm going to be honest with you. We did this in class with non-functional devices, as you could probably tell since we had no hard drive in ours. We did not have access to thermal paste nor was it necessary for us to reapply any since the laptop didn't work from the start. I'm sorry if we provide no guide on how to reapply the thermal paste and I wish you the best of luck in doing it! I am sure there are some other guides on here that include working with thermal paste, if you are not already familiar with it.
Ryan Bump -
Ryan,
Thank you for your reply. All makes sense. Not used thermal paste for years, never had to remove a heat sink for ages.
I can work that out based on the originally paste. Shame it has to be removed though as I’m actually replacing the keyboard\palm rest. The machine is not overheating so I’d prefer to leave well alone if I don’t have to disturb it. Actually, looking at the pictures, it looks like I could just remove the fan screws and leave the heat sink in place,
Thank you for the guide though, good to see it in pictures.
Chris
crwdns2942667:0crwdne2942667:0 8,776
