Lenovo Yoga 2 13" Screen Replacement
  1. Lenovo Yoga 2 13" Screen Replacement, Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga 2 13" Screen Replacement, Screen: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using an opening pick, remove one small black rectangle piece on each of the hinge corners to locate screws.
    • Using a Phillips head screwdriver, carefully remove one 4.8 mm screw from each corner.
  2. Lenovo Yoga 2 13" Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Jimmy, remove the long centerpiece covering between the hinges.
  3. Lenovo Yoga 2 13" Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach the screen from the front panel by sliding the screen up about 2mm. Do not pull too far, as there are still connected wires.
  4. Lenovo Yoga 2 13" Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the gold wire and follow it to two clips. Remove the clips and the clear tape securing the wire.
    • Gently unsnap the wire from the hooks along the perimeter, and remove any tape along the wire.
  5. Lenovo Yoga 2 13" Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga 2 13" Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Completely separate the screen from the laptop.
    • During reassembly, remember to set the screen about 2 mm beyond the lid top edge. Then, slide down to engage the hinges.
crwdns2935229:011crwdne2935229:0
Nichelle
crwdns2935283:003/11/15crwdne2935283:0
1,550 crwdns2915208:0crwdne2915208:0
Marist, Team 1-2, Laflen Spring 2015 crwdns2935289:0Marist, Team 1-2, Laflen Spring 2015crwdne2935289:0
MARS-LAFLEN-S15S1G2
Hi Nichelle,
thanks for your guide. Step 1 and 2 - no problem. But how actually did you do step 3? I can't detach the screen, I can just lift it a few millimeters at the corners or at the side, totally hard..
edit: Ok got it: slide the touch-lcd up a bit :)
Simon - crwdns2934203:0crwdne2934203:0
Hey Nichelle, do you have any recommended vendors for both the screen and the digitizer? Thanks!
Emmanuel Duarte - crwdns2934203:0crwdne2934203:0
I used laptopscreen.com.
ken - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 16,377
