Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement
  1. Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement, Remove the back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement, Remove the back Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew and take out 10, 1/5 cm screws.
    • Unscrew and take out 1, 1 inch screw.
    • I use a piece of tape sticky side up to place screws on, also I label it where they go.
  2. Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement, Pry up back panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement, Pry up back panel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement, Pry up back panel: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the vents facing away from your body I find it easiest to start at the bottom right corner first and gently pry up the corner using a plastic tool.
    • Then slide and pry the plastic tool to the left corner.
    • Then work on the sides.
  3. Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement, Pulling off the back panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement, Pulling off the back panel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement, Pulling off the back panel: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully lift up on the back panel.
    • The back will snap out of place but be careful and don't force it to hard.
  4. Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement, Disconnect the battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement, Disconnect the battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the battery cable out of it's connector. Gripping the wires in the middle gently wiggling the wires back and forth while pulling.
    • With the battery connector out.
  5. Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement, Removing the RAM: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement, Removing the RAM: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement, Removing the RAM: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Note the tabs on each side of the RAM holder,
    • With your fingers or the plastic tool gently move the tabs away from the RAM, the RAM should pop up when both sides or moved.
    • Grip the RAM by the sides and lift out.
crwdns2935229:05crwdne2935229:0
Corbin Schon
crwdns2935283:001/26/16crwdne2935283:0
593 crwdns2915208:0crwdne2915208:0
crwdns2917034:0crwdne2917034:0
Thank you for the guide! It helped me to feel sure about the disassemble.
cacalo219 - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 3,725
