Remove the four 4 mm Phillips #00 screws securing the battery.
Disconnect the battery connector by pulling the battery cable directly out of its port, toward the battery.
Lift the battery up and out of the chassis.
Use an opening tool to pry off the display bezel.
Remove the four 4 mm screws with a Phillips #1 screwdriver.
Flip up the gate on the display ribbon cable, and pull it directly out of its port.
Remove the display from the computer.
