The heat sink transfers excess thermal energy away from the CPU to the fan and cooling system in order to protect the CPU's delicate components.
Remove all twelve 6 mm long screws on the back of the laptop with a Phillips #1 screwdriver.
Pull off the back cover of the laptop. It should come off easily.
Remove all six 7mm screws from the heat sink using the Phillips #1 screwdriver.
Remove the heat sink.
Take note of the gray thermal paste on the back of the heat sink.
Hope someone see this cmt. I cannot lift up the heat sink for some reason. All 6 screws are removed. Any advice?
