Lenovo V15-ADA Wi-Fi Card Replacement
  1. Lenovo V15-ADA Wi-Fi Card Replacement, Back Panel Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo V15-ADA Wi-Fi Card Replacement, Back Panel Assembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 10 marked screws using a Phillips #1 screwdriver from the back plate.
    • M2.5 × 7 mm, Phillips-head (6) (RED circles)
    • M2.5 × 4 mm, Phillips-head (4) (ORANGE circles)
    • The red circles show the longer screws, and the orange circles show the shorter screws.
    • Keep your screws organized. They’re different lengths and must go back in their original positions.
  2. Lenovo V15-ADA Wi-Fi Card Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo V15-ADA Wi-Fi Card Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After removing all ten screws, use a plastic spudger to separate the bottom cover from the laptop.
    • Gently slide the tool around the edges until the clips begin to release.
    • Once all the clips are loose, lift the cover off and set it aside.
    • The Wi-Fi card is located near one corner of the motherboard. It has two antenna wires connected to it (one black and one gray).
  3. Lenovo V15-ADA Wi-Fi Card Replacement, Wi-Fi Card: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the Black wire with your fingers or small ESD-safe tweezers.
    • Lift the connector straight up to avoid bending it.
  4. Lenovo V15-ADA Wi-Fi Card Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the gray antenna wire in the same way.
    • The black wire is the main antenna; the gray wire is the auxiliary antenna.
  5. Lenovo V15-ADA Wi-Fi Card Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew screw holding Wi-Fi card in place.
    • 1x M2 x 3mm, Phillips #1.
    • Keep this screw safe. You’ll need it when installing the new card.
  6. Lenovo V15-ADA Wi-Fi Card Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After removing the screw, the Wi-Fi card will pop up at an angle.
    • Gently pull the card straight out of the slot.
    • Avoid touching the gold connectors and do not bend the card.
  7. Lenovo V15-ADA Wi-Fi Card Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the old Wi-Fi card from the slot.
    • Insert the new Wi-Fi card at the same angle and slide it into place.
    • Press the card down and reinstall the screw.
    • Reattach the black and gray antenna wires by pressing each connector straight down until it clicks.
If your new Wi-Fi card isn’t working:
  • Check that both antenna cables are securely reattached.
  • Verify the card is seated properly in its slot.
  • Make sure drivers are updated in your operating system.
  • Try rebooting and checking BIOS/Device Manager for detection.
  • If the issue persists, reinstall the card or try a different compatible model.
Jacob Schorr
crwdns2935283:002/21/24crwdne2935283:0
442 crwdns2915208:0crwdne2915208:0
University of Kentucky, Team 1-2, Martin Spring 2024 crwdns2935289:0University of Kentucky, Team 1-2, Martin Spring 2024crwdne2935289:0
UKY-MARTIN-S24S1G2
crwdns2936753:030crwdne2936753:0 62
crwdns2942667:0crwdne2942667:0 460
