This guide will show how to access, disconnect, and remove the hard-disk drive from your Lenovo V15-ADA device.
Remove the 10 marked screws using a Phillips #1 screwdriver from the back plate.
M2.5 × 7 mm, Phillips-head (6) (RED circles)
M2.5 × 4 mm, Phillips-head (4) (ORANGE circles)
After removing all ten screws, use a plastic spudger to separate the bottom cover from the laptop.
Gently slide the tool around the edges until the clips begin to release.
Once all the clips are loose, lift the cover off and set it aside.
To start the removal of the battery, disconnect the ribbon cable connecting the battery to the computer.
The battery is held in place by 3 screws. Use the Phillips #0 screwdriver to remove the screws that secure the battery.
M2 × 6 mm, Phillips-head, nylok-coated (3)
Remove the battery from the device after completing steps 1 and 2.
Attach a PH0 head onto the screwdriver and remove screw. (M2 × 6 mm, Phillips-head, nylok-coated)
The hard drive has been successfully taken out.
