If your device isn’t charging or loses charge quickly, it may be time to replace the battery. Follow the instructions below to replace the battery in the Lenovo V15-ADA.
Before you begin this repair, make sure your laptop is powered off and unplugged from the charger.
Remove the 10 marked screws using a Phillips #1 screwdriver from the back plate.
M2.5 × 7 mm, Phillips-head (6) (RED circles)
M2.5 × 4 mm, Phillips-head (4) (ORANGE circles)
After removing all ten screws, use a plastic spudger to separate the bottom cover from the laptop.
Gently slide the tool around the edges until the clips begin to release.
Once all the clips are loose, lift the cover off and set it aside.
To start the removal of the battery, disconnect the ribbon cable connecting the battery to the computer.
The battery is held in place by 3 screws. Use the Phillips #0 screwdriver to remove the screws that secure the battery.
M2 × 6 mm, Phillips-head, nylok-coated (3)
Remove the battery from the device after completing steps 1 and 2.
