To make any repairs on the Lenovo V15-ADA device, you must take the back panel off first. Below are the steps to remove the back panel.
Remove the 10 marked screws using a Phillips #1 screwdriver from the back plate.
M2.5 × 7 mm, Phillips-head (6) (RED circles)
M2.5 × 4 mm, Phillips-head (4) (ORANGE circles)
After removing all ten screws, use a plastic spudger to separate the bottom cover from the laptop.
Gently slide the tool around the edges until the clips begin to release.
Once all the clips are loose, lift the cover off and set it aside.
