Impact damage, water, overheating, and general wear and usage can cause the LCD panel to crack, develop missing pixels, or stop turning on. This guide shows how to replace the LCD panel within the Lenovo V14-IIL laptop. Be sure to remove small parts carefully.
Before using this guide, make sure to review the Lenovo V14-IIL troubleshooting page to review if there may be a solution that does not require component replacement.
Make sure to power off your laptop completely and disconnect from any external power source before beginning the process.
Flip your laptop over and place on a flat surface so you can access the screws on the base cover.
Remove the six 7 mm screws from the back panel of the laptop using a Phillips #0 screwdriver.
Remove the four 4 mm screws from the bottom edge of the laptop using a Phillips #0 screwdriver.
Use an iFixit opening tool to pry apart the case by sliding it along each side of the laptop.
Lift away the back panel and set it aside.
Using a Phillips #0 screwdriver, remove the four 5 mm screws from the hinges of the laptop.
Lift up the latch and gently pull the display cable free.
Using the spudger, disconnect the two wireless LAN cables (black and gray) from the wireless LAN card.
Remove the LAN cables from the three brackets on the fan.
Lift the display assembly away from the base.
Slide the cable hinge cover to the right.
Pull the part away from the screen.
Use the iFixit opening tool to separate the bezel panel.
Slide the opening tool all the way around to loosen the bezels on all sides.
Lift away the bezel panel.
Using a Phillips #0 screwdriver, remove the six 2.2 mm screws from the hinges of the laptop.
Using a Phillips #0 screwdriver, remove the four 2.8 mm screws from the hinges and top corners of the laptop.
Lift up the LCD panel and gently turn it over as though closing the lid.
Lift the bracket securing the cable in place.
Gently pull the cable until it disconnects and lift away the old LCD panel.
