Lenovo V14 G2 ALC how to install second hdd/ssd
    • 1. open laptop, you need a phillips screw (4 points) screws are flat.
    • 2, navigate to the little ffc concetor, should be on your right hand side across the empty gap
    • connect sata end of ffc to 2'5 hdd/ssd, and install the ffc end to the small flappy bit (DON'T REMOVE THE BLUE THING)make sure the ffc cable has room to get out so you can make the connection, the cable may be adjusted to reach the slot.
  1. Lenovo V14 G2 ALC how to install second hdd/ssd, insert the ssd: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • your ssd/hdd should fit, in rare circumstances, you may need to adjust brackets or something, my Samsung 2'5 SSD fit right in with a light push.
    • this step is obvious, but i will include it, just put the cover back on and screw everything back in.
there, now you have another drive in your v14 g2 alc.
holdmyapplejuice
crwdns2935283:011/16/23crwdne2935283:0
121 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 489
