Lenovo Thinkpad Twist s230u Battery Replacement
  1. Lenovo Thinkpad Twist s230u Battery Replacement, Hard Drive: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Thinkpad Twist s230u Battery Replacement, Hard Drive: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the laptop over.
    • Using a Phillips #1 Screwdriver, unscrew the screw on the bottom left corner.
  2. Lenovo Thinkpad Twist s230u Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the iFixit Opening tool, loosen the hard drive cover.
  3. Lenovo Thinkpad Twist s230u Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the hard drive cover.
  4. Lenovo Thinkpad Twist s230u Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Thinkpad Twist s230u Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the hard drive by sliding it out.
  5. Lenovo Thinkpad Twist s230u Battery Replacement, Keyboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Philips #1 screwdriver to remove 2 screws on the bottom of the laptop.
  6. Lenovo Thinkpad Twist s230u Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to loosen the keyboard around the edges.
    • Carefully push the keyboard towards the screen to unlatch it.
    • Do not push too hard, as there are ribbon cables attached to the keyboard.
  7. Lenovo Thinkpad Twist s230u Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift up the keyboard to access the wires underneath.
    • Be careful not to break the ribbon cables attached underneath.
  8. Lenovo Thinkpad Twist s230u Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo Thinkpad Twist s230u Battery Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo Thinkpad Twist s230u Battery Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the small black flap on each of the ribbon cables. It should lift with a slight effort.
    • Pull out the ribbon cables and remove the keyboard from the device.
  9. Lenovo Thinkpad Twist s230u Battery Replacement, Upper Casing: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip your device over.
    • Use the Phillips #1 screwdriver to remove the nine screws.
  10. Lenovo Thinkpad Twist s230u Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Thinkpad Twist s230u Battery Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the device back over and open the top.
    • Use the Phillips #1 screwdriver to remove the seven silver screws.
    • Disconnect the three cables inside the case.
    • Lift up the brown tab and disconnect the ribbon cable.
  11. Lenovo Thinkpad Twist s230u Battery Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Thinkpad Twist s230u Battery Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Close the lid and turn the device around.
    • Use the iFixit Opening Tool to lift up and remove the tab on the back.
  12. Lenovo Thinkpad Twist s230u Battery Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Thinkpad Twist s230u Battery Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the device back around and reopen it.
    • Use the iFixit Opening Tool to disconnect the top of the case from the bottom.
    • Lift up the top of the case and slide it out from under the screen.
  13. Lenovo Thinkpad Twist s230u Battery Replacement, Battery: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Thinkpad Twist s230u Battery Replacement, Battery: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the single silver screw using the Phillips #1 screwdriver.
  14. Lenovo Thinkpad Twist s230u Battery Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the colored cables.
  15. Lenovo Thinkpad Twist s230u Battery Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the battery out of the laptop.
Arthur McPeak
crwdns2935283:001/14/20crwdne2935283:0
691 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S1-G3, Cromer Twal Spring 2020 crwdns2935289:0Embry-Riddle Aeronautical University, Team S1-G3, Cromer Twal Spring 2020crwdne2935289:0
ERAU-CROMER TWAL-S20S1G3
What's the voltage that charges the battery? I'm getting 1.8v and the battery always stays at 0% but i can use it for some minutes
The voltage at battery port
Jojina - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 74
crwdns2942667:0crwdne2942667:0 5,094
