Remove the eight 14mm screws using the Phillips #0 Screwdriver.
Use the spudger to disconnect the ribbon cable.
Remove the tape, using the spudger if necessary.
Use the Phillips #0 Screwdriver to remove the screws of the frame around the trackpad circuit board.
