If you are encountering issues with your keyboard, there is a possibility that you might have to replace it. You can utilize this guide to receive step by step instruction to complete this task manually by yourself.
Remove the battery by pulling on the two sliding buttons next to the battery.
Remove the seven 5mm screws on the back cover using the Phillips #0 screwdriver.
There is no need to remove the back panel for a keyboard replacement on the T450s
Also, there are eight (8) screws: one is right under the battery.
Remove the two rubber stoppers from where the battery previously was.
This can be done without removing the back cover. Slightly more difficult but only by about 1mm or less.
Flip the laptop, shift the keyboard upwards by applying force to the two indents on the keyboard.
Remove the six 5mm screws that are on the keyboard using the Phillips #0 screwdriver.
Lift the keyboard and flip over exposing the connection to the motherboard.
Remove the plastic covering and detach touch point and keyboard cable.
There are TWO keyboard cables, one is hidden below the other, be careful not to yank it. To undo the cables, lift the black part up and away.
If after replacement your keyboard has some keys clacking, make sure you slid the keyboard all the way back. Even a small amount can make some keys feel weird.
