Lenovo Thinkpad T440s Fan Replacement
  1. Lenovo Thinkpad T440s Fan Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Thinkpad T440s Fan Replacement, Back Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Make sure to power down and turn off your device before proceeding with the repair.
    • Flip your laptop over so that the backside is facing you.
    You should also disable the internal battery in the BIOS first too.
    martin8777 - crwdns2934203:0crwdne2934203:0
  2. Lenovo Thinkpad T440s Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #1 screwdriver, remove the eight screws securing the backplate.
    • Don’t try to force screws which won't come out. They are held in place by a stopper on the reverse side. This will not prevent you from removing the backplate.
    Only the bottom left and right screws can be pulled out. Don’t try to force the others.
    darvu - crwdns2934203:0crwdne2934203:0
    +1 — Only the bottom left and right screws can be pulled out. Don’t try to force the others.
    Thomas Hoddinott - crwdns2934203:0crwdne2934203:0
  3. Lenovo Thinkpad T440s Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Thinkpad T440s Fan Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the metal spudger, wedge it in the seam where the backplate meets the front plate and run the tool along the seam to separate the backplate.
  4. Lenovo Thinkpad T440s Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back panel from the device.
  5. Lenovo Thinkpad T440s Fan Replacement, Fan: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Thinkpad T440s Fan Replacement, Fan: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Phillips #1 screwdriver to remove the four screws holding in the fan assembly.
  6. Lenovo Thinkpad T440s Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo Thinkpad T440s Fan Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo Thinkpad T440s Fan Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the fan out of it's compartment to gain access to the cable connection, firmly grab the cable and pull it out of it's housing.
    La ventola del t440 è compatibile con il t440s?
    Sabrina Servietti - crwdns2934203:0crwdne2934203:0
    Is it easy to disconnect the fan from the heat sink and replace just the fan?
    Robert - crwdns2934203:0crwdne2934203:0
Terelle Montalvo
crwdns2935283:010/22/18crwdne2935283:0
1 495 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S1-G5, Simcock Fall 2018 crwdns2935289:0UMass Dartmouth, Team S1-G5, Simcock Fall 2018crwdne2935289:0
UMASSD-SIMCOCK-F18S1G5
It would be helpful to have something about the fan too!
Where to get it, or at least the model number!
Iraj V - crwdns2934203:0crwdne2934203:0
Useless info. This is the heatsink (with fan) replacement, NOT fan replacement. The poster is a moron.
Victor Song - crwdns2934203:0crwdne2934203:0
Victor - The fan and heatsink are attached to one another. How would you propose one replace the fan only? If you have a method, please create your own guide if this one was authored by such a “moron”. Jeez.
tomwedell -
crwdns2936753:030crwdne2936753:0 44
crwdns2942667:0crwdne2942667:0 6,713
