The possible screens for this model of the T440s are the
- AUO display B140HAN01.2 (FRU: 04X0436)
 - LG display LP140WF1 (sp)(k1) (FRU: 04X0626)
I had a AUO installed and replaced, so no judgement on the quality of the LG display, which can be followed in various Thinkpad forums.
While booting, press the F1 button to enter the BIOS.
Go to "Config" and then to "Power".
Select "Disable Built-in Battery" and press Enter.
You will be asked to proceed. Select "Yes".
The laptop shuts down.Unplug the laptop from AC.
Remove the battery.
Start removing the front bezel in the lower display corners using a prying tool.
Remove 4 screws M2XL3 with screwdriver.
Remove the rear bezel with the prying tool.
Carefully release the display, turn it around and place it on the keyboard.
Remove the connector together with the label.
crwdns2935229:019crwdne2935229:0
crwdns2947412:07crwdne2947412:0
Did this upgrade with my T440 and worked great, used a LP140WF1 / B140HAN01 display added some much needed pixels and IPS viewing angles. I bought from Aliexpress Store: Kevin trade shop.
What about T440s with touch panel?
I do not possess a touch device, sorry.
Can this be done as an upgrade
You mean from “normal” to touch display? I cannot comment on a touch device…
