Lenovo Thinkpad T440 laptop Keyboard Replacement
  1. Lenovo Thinkpad T440 laptop Keyboard Replacement, Remove battery and fascia slide stops: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Thinkpad T440 laptop Keyboard Replacement, Remove battery and fascia slide stops: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Power down the computer and remove the external battery.
    • Using a pick tool, dental pick, tweezers, small flat screwdriver, or similar probe, carefully remove the two small rectangular rubber plugs located inside the battery compartment.
    • NOTE: Do not pierce or damage the plugs. They help provide spill resistance.
  2. Lenovo Thinkpad T440 laptop Keyboard Replacement, Expose and loosen the screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo Thinkpad T440 laptop Keyboard Replacement, Expose and loosen the screws: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo Thinkpad T440 laptop Keyboard Replacement, Expose and loosen the screws: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the two small oval depressions in the keyboard fascia, just below either Ctrl key.
    • Using a flat screwdriver or narrow spudger in the depressions, slide the fascia up towards the hinges about 3mm (0.1 inches). The top edge slips beneath the bezel.
    • This exposes six Phillips screw heads, located in the 3rd and 5th rows of the key area. Loosen them.
  3. Lenovo Thinkpad T440 laptop Keyboard Replacement, Free the keyboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo Thinkpad T440 laptop Keyboard Replacement, Free the keyboard: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo Thinkpad T440 laptop Keyboard Replacement, Free the keyboard: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the keyboard up so the function-key-edge slips a small distance (3mm) beneath the keyboard bezel, freeing the arrow-key-edge.
    • Using a flathead screwdriver or spudger, lift the arrow-key-edge of the keyboard until it clears the bezel above the palm rest.
    • Slide the keyboard away from the screen, with the arrow-key-edge still above the palm bezel, until you have exposed a gap near the function-key-edge.
    • Lift the function-key edge and rotate the keyboard to expose its back. Adhesive on the ribbon cables may tug but will easily loosen with a gentle pull.
  4. Lenovo Thinkpad T440 laptop Keyboard Replacement, Loosen the spill protection grommet: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There is a large rubber grommet separating the keyboard from the motherboard. Its job is to help shield the motherboard in case a liquid is spilled into the keyboard.
    • The top edge of the grommet has a notch. Insert a fingertip or screwdriver and carefully pull the grommet loose. It is held in place by a weak adhesive.
    • Slide the grommet along the keyboard ribbon cable, towards the keyboard, and out of the way of the ribbon cable sockets.
    • NOTE: the thin grommet tears easily! This damage can reduce your laptop's ability to withstand a liquid spil.
  5. Lenovo Thinkpad T440 laptop Keyboard Replacement, Remove the ribbon cables: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Thinkpad T440 laptop Keyboard Replacement, Remove the ribbon cables: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There is a black plastic keeper bar holding the keyboard ribbon cable down. Slide a screwdriver just beneath the edge and carefully flip it up.
    • Slide the wide keyboard ribbon cable out of the socket.
    • There is another black plastic keeper holding the trackpoint cable in place. Slide a screwdriver just beneath the edge and flip it up.
    • Slide the narrow trackpoint ribbon cable free of the socket.
    • The keyboard is now free.
crwdns2935229:014crwdne2935229:0
jadeters
crwdns2935283:008/27/10crwdne2935283:0
1.457 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 105
crwdns2942667:0crwdne2942667:0 11,432
