Follow this guide to replace the hard drive on your Lenovo ThinkPad E540 laptop.
Push the battery release switches away from each other.
Remove the three 1.2mm Phillips #00 screws from the bottom panel.
Use a plastic opening tool to pry off the bottom panel.
Remove the four 1.2mm Phillips #0 screws from the hard drive.
Pull up on the hard drive to allow for removal.
Disconnect the hard drive and pull out to remove.
Thanks for this invaluable and easy guide.
Is it possible to replace the hdd with an ssd for this model? If so, which ssd would fit this laptop’s hdd socket?
Many thanks in advance.
