Follow this guide to replace the fan on your Lenovo ThinkPad E540 laptop.
Push the battery release switches away from each other.
Remove the three 1.2mm Phillips #00 screws from the bottom panel.
Use a plastic opening tool to pry off the bottom panel.
The heatsink and fan are found on the right side.
Remove the two 1mm Phillips #0 screws from the fan.
Unscrew the four 2mm Phillips s#0 screws from the heatsink.
To remove the heatsink and fan, pull the fan upwards and towards the center.
