Lenovo ThinkPad x120e RAM Replacement
  1. Lenovo ThinkPad x120e RAM Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad x120e RAM Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the laptop upside down and locate the battery latches under the battery.
    • Place your thumbs on both latches and push the latch inwards.
    • With your thumbs still on the latches, slide the battery out of the laptop.
    • To install a new battery, simply slide the battery back in the slot. Then, check if both battery latches are locked
  2. Lenovo ThinkPad x120e RAM Replacement, Back Cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad x120e RAM Replacement, Back Cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad x120e RAM Replacement, Back Cover: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the Phillips #0 screwdriver, remove the three 4 mm screws that are securing the bottom cover.
    • Remove the backplate carefully, making sure not to bend the cover.
  3. Lenovo ThinkPad x120e RAM Replacement, RAM: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad x120e RAM Replacement, RAM: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad x120e RAM Replacement, RAM: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Anti-Static Wrist Strap
    $7.95
    • Push the two mounting clips on either side of the RAM away from each other.
    • While doing this step, wear an anti-static wrist strap. This will prevent you from generating static that could damage the RAM module.
  4. Lenovo ThinkPad x120e RAM Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad x120e RAM Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The RAM should now be lifting up at an angle.
    • Slide the RAM stick out in the direction the angle is facing.
    • While installing the new RAM stick, push the stick down at an angle and make sure you secure it with the small clips at both sides.
Jacob Fronzaglia
crwdns2935283:010/25/21crwdne2935283:0
787 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 3-4, Sinclaire Fall 2021 crwdns2935289:0UMass Dartmouth, Team 3-4, Sinclaire Fall 2021crwdne2935289:0
UMASSD-SINCLAIRE-F21S3G4
crwdns2942667:0crwdne2942667:0 468
