The screen is a crucial part of a laptop. A screen that is damaged and broken can cause many problems in the display of information. Follow this guide to learn how to replace the screen on a Lenovo Thinkpad Yoga 370.
Before beginning this repair, power off your device and unplug from your power adapter.
Remove rubber plugs on the lower corners of the screen
Unscrew screws under the rubber plugs
Remove the four 4 mm screws along the bottom of the display.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using tweezers, remove the tape from the display cable below the screen.
Slide the screen downwards towards the keyboard.
Lift the screen slowly from the frame when the screen is slid down completely.
Flip the screen over and lay face down on the keyboard.
Peel the tape off from the back of the screen, connecting the display to the device.
Remove the screen.
I strongly recommend to at least unplug the battery before replacing the screen. I fried a motherboard once by manipulating a screen ribbon while the battery was still plugged in.
You should always unplug the battery before working on a device anyway.
