crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
Remove the stylus from the device and set it aside.
Using the Phillips #00 screwdriver unscrew the eight circled 4mm screws until you hear a click.
Using the plastic opening tool, work around the edges of the bottom cover to undo the plastic clips.
Gently remove the cover by placing your fingers around the edges.
With your fingers, fold back the plastic cover highlighted.
Using two fingers, gently remove the battery connectors.
Using the Phillips #00 screwdriver, remove the two 4mm screws.
Remove the battery.
Remove the four 2 mm screws holding the heatsink to the motherboard using the Phillips #00 screwdriver.
crwdns2935267:0crwdne2935267:0Tweezers$4.99-
Disconnect the fan's bundled cable from the motherboard using a small set of tweezers or simply pull them out gently.
Lift the fan and heatsink from the motherboard; then flip both toward the motherboard.
Detach the wire from the perimeter of the fan casing.
Remove the fan and heatsink.
