Lenovo ThinkPad Yoga 11e Gen 6 Hinges Replacement
  1. Lenovo ThinkPad Yoga 11e Gen 6 Hinges Replacement, Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad Yoga 11e Gen 6 Hinges Replacement, Screen: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Wearing the anti-static wrist strap will prevent a static shock from damaging the components in the laptop.
    • Disconnect the laptop from power and make sure it is completely powered off.
    • Turn the laptop facing down.
    • Loosen the eight captive screws using a JIS #0 screwdriver.
    • The screws are attached to the panel and cannot be removed.
    • Carefully remove the panel.
  2. Lenovo ThinkPad Yoga 11e Gen 6 Hinges Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad Yoga 11e Gen 6 Hinges Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad Yoga 11e Gen 6 Hinges Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully disconnect the two sliding connectors in the left and right corner.
    • Disconnect the sliding connector on the Wi-Fi board.
    • Loosen the four 9.7 mm screws on the hinges in the top left and right corners using a Phillips #0 screwdriver.
    • Carefully lift the closest part of the laptop away from the screen side of the laptop.
  3. Lenovo ThinkPad Yoga 11e Gen 6 Hinges Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad Yoga 11e Gen 6 Hinges Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad Yoga 11e Gen 6 Hinges Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using tweezers, gently pry and remove the covers on the LCD strip.
    • Remove the two 3.3 mm screws that were previously under the covers on the LCD strip using a Phillips #0 screwdriver.
    • Carefully lift and remove the LCD strip.
  4. Lenovo ThinkPad Yoga 11e Gen 6 Hinges Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad Yoga 11e Gen 6 Hinges Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad Yoga 11e Gen 6 Hinges Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 3.3 mm screws from the silver panels using a Phillips #0 screwdriver.
    • Remove the two 3.3 mm screws from the LCD panel using a Phillips #0 screwdriver.
    • Carefully lift the screen towards you. You may use the spudger to assist lifting the screen. There will be one more connector on the side of the screen.
    • Carefully remove the ribbon connectors by gently pulling with your fingers.
  5. Lenovo ThinkPad Yoga 11e Gen 6 Hinges Replacement, Hinges: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad Yoga 11e Gen 6 Hinges Replacement, Hinges: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad Yoga 11e Gen 6 Hinges Replacement, Hinges: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four 3 mm screws that are closest to you using a Phillips #0 screwdriver.
    • Remove the two 4 mm screws that are further from you using a Phillips #0 screwdriver.
  6. Lenovo ThinkPad Yoga 11e Gen 6 Hinges Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad Yoga 11e Gen 6 Hinges Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the stopper and pull it out of the right hinge.
    • Remove the wire from the hinge.
  7. Lenovo ThinkPad Yoga 11e Gen 6 Hinges Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad Yoga 11e Gen 6 Hinges Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad Yoga 11e Gen 6 Hinges Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab the stopper and pull it out of the left hinge.
Lex
crwdns2935283:010/02/24crwdne2935283:0
515 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team 1-1, Carnegie Fall 2024 crwdns2935289:0Eastern Washington University, Team 1-1, Carnegie Fall 2024crwdne2935289:0
EWU-CARNEGIE-F24S1G1
Is the hinge tension adjustable if it's holding power is weak or is replacement the only option?
gfriedman99 - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 47
crwdns2942667:0crwdne2942667:0 304
